Re: The wires broke on the switch, I have resoldered them...
Before you rewire your clipper I will put a video together for you, if you rewire your clipper wrong the clipper will short out and burn the clipper. please send email to [email protected] for video.
Cathy,RE POST with your make and model# and full question, and I am sure we can help. show your appreciation by pressing the helpful button and follow me on fixya for more tips and info.
just strip both ends and resolder the connection and cover with tape. If you can't solder, you can just use tape, or wire ties and electrical tape. 1/4 inch of leads on both ends, twist and tape.
IV got a speed fight 2 100cc iv got no lights back are front only brake light works iv also got a speed fight 1 witch i'm using for parts iv changed the light switch cos the starter bottom dint work now iv swaped it it works but the old switch for lights was broke so it dint work am not sure if is as to be the same switches as there different
You can replace the two switches on either handlebar switch housing. Take the switch housing apart and unsolder the wires from the bad switches. Take the small screws out and replace the switches with new ones. Resolder the wires.
The wire that runs the length of the handle and terminates at the engine is attached to a spade or bullet connector that is attached at the magnetto (spark plug wire comes from the magnetto). if it jus broke off you should be able to see where it attaches on the connector.
