Hi
I have Nokia n82 after change its body (housing) its main camera not working. when i open camera shutter it do nothing when i use camera from application it just open front camera.
Please help me in this regard
Hi Dear!
It is Canon product problem error code in most of case.
I need model of your camera unit, but simply the error "err99" usually come from functionality related signal that does not work properly in most of case and in past. So it is so wide category problem. The problem priority description will be defective shutter unit, CF card pin acceptance unit, main circuitry (main pcb), and main mirror sequence in camera body. Next in camera lens it would be diaphragm unit defect is number one otherwise main pcb. So, you can simply eliminate one doing separate of the operation. Remove lens from camera body and set Manual mode (M mode on dial or LCD display), remove memory card and change on menu function(without memory card) then press shutter button several time. If no error come out, then put memory card in camera press shutter button several time. If no error come out then 200% is lens diaphragm unit defect,and 5% is main pcb problem. All of these problem I recommend to bring any local repair shop doing do to difficulty.
Hope You Luck! A Professional Camera Clinic Guy!
Can you describe what your phone is displaying when you switch it on? Have you ever taken a backup of it? What does it show when you connect to Nokia PC Suite on your PC?
hi this is ajay i have nokia n82 .. mobile . the problem is camera is not working some times .when i open back lens cover the camera start but is show black screen .iin some times .. and another bug is buletooth . when i on buletooth it says unable to perfom plz helpp meee .....
friend,
Pls., check whether a an application named BAR CODE reader is installed and if is turned ON,then Ur IR will always in search of a bar code if fone camera shutter is slide open
