SOURCE: error 1513, partition magic
YEP ... you can not re-size with success any partition that contain a operating system ...just for the simple cause that you can not format it with success after ...so ..if you want to re-size them ...just reinstall the os...and format the partitions during the re-installation ...but keep in mind that you will loose any data on the hdd ..so ..even when you use partition magic..the new rebuild partition need to be formatted if not ...it will be just the same but with some unallocated space ...and with the other smaller... so reinstall and rebuild both partitions...be sure you know what you are doing cause you might end up with a dual boot ..or worse ...with a single partition ....etc
SOURCE: Partition Magic hides drive & gives error 302
See if this will work,click on the recycle bin,put magic v8 and boot magic in it,and see if the effect is the same.
