Health & Beauty Logo
Posted on Apr 12, 2011
Where will I find a manual and batteries fot the WS500L scale
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Apr 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
2187
Points
22
Where will I find a - moz-screenshot.jpgHttp://docs.google.com/viewer?a=v&q=cache:NLeMJyZhXv0J:www.casualmale.com/store/en_US/static/X1136_Scale.pdf+manual+and+batteries+for+the+WS500L+scale&hl=tl&gl=ph&pid=bl&srcid=ADGEESjk580F5aOwvas46s2wS22RFAGDlHlDy973LdCaRHlyJutQCSswrMzl39fsLp9OR4edKpGh8Apobta6OWPX1MPGfyX39anoVWvL9i9SfNJjON6FKMoDICI6iS3i0ynCfQy6aTbd&sig=AHIEtbR9OwF95YiSOOrgkhOYMVs661jWvQ
Calibration manual for a Siltec WS500L person weigher.
Removing the power source should reset it. Personal scales do not normally need calibration.
Or contact them direct
https://siltec.balances.com/
https://scaleman.com/ws500l-large-platform.html
How to reset BFM144DQ3-99 scale, lose manual!
To reset the BFM144DQ3-99 scale, you can try the following steps:
  1. Remove the batteries from the scale.
  2. Press and hold the power button for 10 seconds.
  3. Release the power button and wait for 10 seconds.
  4. Reinsert the batteries.
  5. Press the power button to turn on the scale.
If the scale still does not reset, you can try contacting the manufacturer for assistance or searching online for a copy of the user manual.
How do I reset the scale?
If the scale is an electronic version, remove the batteries and wait a minute or two before replacing the batteries. That will probably zero the scale. If that doesn't work, it's time to buy new batteries.
Why won't my Siltec WS500 scales won't turn on?
It's a capacitor. Your son is probably right.
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
1helpful
7506 Glass digital lithium scale battery replacement. I need the battery no. please...
The lithium battery is a 3-Volt CR2032. The manual for the scale is available here: http://www.taylorusa.com/media/IBs/7506_ib.pdf . Additional information and a link to the manual is available here: http://www.taylorusa.com/weight-management/glass-electronic-scales/glass-lithium-electronic-scale.html .
I hope this helps.
4helpful
3answers
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Hello: my digital food scale (taylor digital biggest loser brand) goes on but it does not weigh anything. its stays at zero. i've had it a year but only used it once or twice, so its almost never been...
Hello, Maclay55 -
I hope you checked the owner's manual first, the troubleshooting / problem solving section.
It wouldn't hurt to put new batteries in the scale (2 AAA batteries).
Note: From the instructions for the scales:
6. Do not store scale where you store cleaning chemicals. The vapors from some household products may affect the electronic components of your scale. Do not store scale on its side.
7. This scale is an extremely sensitive weighing device. In order to prevent run down of the battery, do not store anything on the scale.
8. Do not dispose of batteries in fire. Batteries may explode or leak. Do not mix old and new batteries. Do not mix Alkaline, carbon-zinc (standard) or Nickel-Cadmium (rechargeable) batteries. Remove the batteries if the scale will not be used for a long period of time.
Source:
1037BL The Biggest Loser by Taylor Stainless Steel Platform Scale Instruction Manual, pages 4-5
http://taylor-enviro.com/media/IBs/1037BL_ib.pdf
If installing fresh batteries does not work, then I suggest you call the Taylor USA Consumer Help & Support department. This is the link to the web page with the US and Canadian telephone numbers:
http://taylor-enviro.com/taylor-support/
Best wishes.
Top Siltec Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Siltec Health and Beauty Expert? Answer questions, earn points and help others
