Hi, my samsung c5220 keeps losing time, whether its fully charged or not. i seem to have to reset it in settings all the time & i am getting so frustrated with it! please help.
its not good news the phone is blacklisted in the united kingdom which is why the phone was locked to Telstra as soon as it was brought back into the united kingdom the blacklisted phone company has restarted the blacklisted barring and hence froze the phone.
before despairing try a few things first try taking to a mobile phone shop and ask them to unlock it if they refuse take it to a market stall mobile phone unlocking stall and they will do it for you however if the phone is blacklisted/barred in the united kingdom you will not be able to make or receive calls. and they do charge. try taking the chip out and booting the phone up without the sim card in and changing the network settings and see if that works .hope this helps
Hi you can purchase network unlock code for your samsung C5220 mobile from sites like Prounlocking.com here they render unlock code for all mobile models at reliable cost ..You first check that whether they are rendering code for your country and network provider ..If yes then pay for it and unlock your phone ...
Hi. I would recommend that you visit a SAMSUNG UNLOCK CODE website for your Samsung c5220 unlock codes. Just specify the phone brand and model with your IMEI numbers as well as the country and network the phone was purchased from. To get the IMEI number, dial *#06# using your phone keypad.
Had same problem with same code. Need to hard reset phone (at your own risk of losing personal information). Turn phone on & type *2767*3855# then let it reset itself. Good luck :)
Please check whether the Reader is fully charged. Connect the Reader to the Computer and keep it connected at least 4 hours to get it fully charged. If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object. That should resolve the issue.
Connect the Reader to the Computer using the supplied USB cable and check whether it is charging,. If it's charging , then keep it connected from at least 4 hour to get it fully charged. If its fully charged, perform a soft reset. To soft reset, just press the RESET button. After soft6 resetting charge it for at least 4 hours., That should resolve the issue. All the best! !
you need to hard reset it. it will be like factory setting. follow below procedure to hard reset. you will loose personal data on phone memory like contacts,sms,settings, etc.
Press reset pin button ONCE (do not hold)
Once you see the Samsung Omnia appears on the screen, immediately press the SEND and END key simultaneously
Then the screen appears asking you whether you are sure to format
