All engines do this when they are cool. But you don't understand it just because the choke works well... Your engine comes with a carb or an injection system? The choke is not working as it seems. You must fix the choke or change the carb!
My 2e engine does not show oil indicator and hand brake indicator in my dash board, so with that the battery indicator light comes on.Now the problem is that my dash board becomes dark and brake lights does show if you apply brakes and the vehicle does not start with its ignition key, but when you push start the vehicle it starts and if you pull the h/brake lever the warning ligth comes up. if you switch on the park lights they show up. i am asking what must be wrong with my car?
Well this engines are notorius to rougth idle, but my sugestion is to inspect your coolant temp sensor, check for corrotion in conector if any clean or replace conector, your engine has two temp sensor one is a single wire for your temp gage and other believe green conector with two wires this is for your computer, if no rust or corrotion found replace the sensor.
good luck
