My webcam night mode is turn off how can i turn it back on
Face Recognition Usually you'll find the webcam at the top and middle of the laptop screen. One unique feature included with the webcam on newer Toshiba laptops including the Satellite Pro, Portege and Qosmio models is facial recognition. Instead of having to type in a password when you open the laptop, you can set up the computer to recognize your face and automatically load your settings. b> Setup b> To access the face recognition feature on a Toshiba laptop, open the laptop to the registration screen and click the Face Recognition icon. Look at the circle that appears on the screen and align your face so that it fits within the circle, and then click "Next." At the next page, enter your name and password and click "OK." The next time you use the computer, click on your Face Recognition icon from the main screen and look at the webcam so it can recognize your face and load your settings. b> Night Mode b> If you're in a low-light situation you can take advantage of the webcam's Night Mode effect. To turn it on, open the Camera Assistant by clicking the Start button, and then select "All Programs."
Select the "Camera Assistant" folder and then select the "Camera Assistant" software. Once it's open, hover your mouse over the far left hand side of your laptop screen. This will cause a number of webcam icons to appear. Click the "Properties" icon, which looks like a box with a pen over the top left of the box. Click the "Night Mode" check box from the Properties window and then click "OK." b> Other Profiles b> You can also alter other effects and features of the webcam from the Camera Assistant. First open the Camera Assistant by clicking the Start button, and then select "All Programs." Select the "Camera Assistant" folder and then select the "Camera Assistant" software. Then hover your cursor on the far left of the screen until you see the webcam menu appear, and select the "Properties" icon. Then click on an individual "Profile" tab to adjust the white balance, lower or raise the brightness, or correct the colors. As you click on the adjustment, you should see the change reflected in the way the webcam is displaying on your laptop. When you've selected the settings you want, click "OK" from the Profile window.
