Your xbox 360 may not actually be on if there's no green light and your controller won't connect. If pressing the power button doesn't turn on the console/green light doesn't come on then your motherboard may be bad.
There's a little button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around thexbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I think there's a little symbol of air waves next to the button. Try this it should fix your problem
To connect the controller to your Xbox 360 console, follow these steps:
Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
no that's not good the motor is working over time you need it looked at quick or the moter will give up and then it will be a bigger job more money try thhttp://www.gamevania.com/XBOX_360/repair.phpis site first.
does it make noise when u press edject; like it trys 2 open it ?
if so try pressing gently the door up or down (or left & right if ur 360 is lying down)it should help. I have the same prob but as never been able 2 pinpoint an issue
tell me if it work
