Olympus EVOLT E-410 Digital Camera Logo
Posted on Apr 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an olympus e410 camera and the images on the memory card are saving as an "ORF" file and will not open in windows. how do i reset my camera to factory settings??
Anonymous
Level 2:
Scholar:
  • Expert 175 Answers
  • Posted on Apr 04, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
175
Questions
0
Helped
36138
Points
225
I have a suggestion. ORF is probably "Olympus Raw File" format and you need software to open raw files. See if your camera came with software to do this or use GIMP, PHOTOSHOP, Adobe lightroom. Read your owners manual and change from RAW file to JPG formats. That way, almost any program can open them.
1helpful
Invalid image olympus
I would take them to a computer and copy them to it, and see if you can read them there. It may be that there's some bad sectors on the removable media (memory card), or the camera itself is having some issues reading it. Either way, if they are recoverable, your best bet is to move them to something that is more stable, and as soon as possible.
Once they are on the computer, try to open them in whatever software can do so. If they're a RAW camera format, you'll need a special codec (driver-sort of thing) or software to read them. If you're saving them as JPEG/JPG or another common file type, your computer should be able to open them natively.
If they are still unable to be opened (and give you errors) then either the memory card is bad, or something is wrong with the way the camera is saving the files. In either case, I would replace that memory card as soon as possible.
Mar 16, 2014 • Cameras
Cant upload photos
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
23helpful
5answers
How to recover pictures from sony cybershot
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this photo recovery software called asoftech photo recovery
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
10helpful
4answers
I accidently deleted my images from the fujifilm finepix av100 camera, can i get them back. please help
Install and open asoftech photo recovery software, select the memory card, and click 'Start' button.
Saving images from S5 Pro directly to laptop hard drive -how?
Hello Brian,
Are you writing to the camera memory because your card is full?
I'm not sure what USB auto/fixed is meant to do but try this.
Connect you camera to the pc as normal and switch the camer on.
The camera may ask you if you want USB or pictbridge, choose USB.
XP Then tries to offer you the best way to get at the photos. Rather than use the transfer option us the open as a folder option.
If XP doesn't offer anything click and open my computer, look for your camera it will appear as a new hard drive.
Click on the new hard drive, normally with olympus you get a folder, the first is you camera memory, click on that you should see photo's and another folder.
Copy or cut and past the photo's to a new folder on your PC. The click on the last folder, should be you memory card, move those photo's as before.
Having copied all photos you can delete them from you camera memory and card using the PC. Just as you'd delete any file.
With luck you should be back in action, a whole card to fill................. Good Luck.
Olympus Camedia D-540
Try photo recovery software to rescue the lost photos, here are some you may rely on.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the memory card in case the original files(your pictures) are overwritten.
Cannot View Uploaded File
try opening the photos with any other viewing software you have - paint, windows picture and fax viewer to name but 2. If you get the same results then the files are probably corrupt, and the probability is that your memory card could be causing the problem, try another card and see if pictures you take can be viewed. Try uninstalling and reinstalling the camera and the olympus software, it just might help. If this doesn't work please post again and we could give you some info on software for recovering corrupt and deleted files. Hope this helps :)
Move images saved to the internal memory to the optional xD-Picture Card
The images saved to the internal memory can be copied to the xD Picture Card, but you cannot copy images from the xD Picture Card to the internal memory. Before you choose to copy the files to the xD card be sure that there is enough room on that card. To copy the images to the xD card make sure the camera is powered on, then and press the menu button. Use the down arrow key to navigate through the menu to the BACK UP feature. Use the right arrow key to enter the Back Up screen and select YES to copy the images to the xD card, or NO if you choose not to coy the image files.
RAW quality mode option
In the RAW mode, the image is compiled of raw data with no compression and no enhancing settings from the camera such as sharpness, contrast etc. It provides a higher dynamic range with the maximum image quality without being processed, so the user can apply his/her own changes to the file. The file will have a .ORF (Olympus Raw File) extension. It can be read using a supplied PhotoShop Plug-in or the Olympus Camedia 2.5 program.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
