Cell Phones Logo
Posted on Mar 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Phillips CD 235 and it showed low battery in the display. I have inserted new batteries and left it for 24 hours to recharge but the screen and phone are dead. I know it is not the batteries so what is the problem?
Level 3:
  • Philips Master 17,130 Answers
  • Posted on Mar 30, 2011
Philips Master
Level 3:
Answers
17130
Questions
0
Helped
3635807
Points
52372
Please try the old batteries back to the phone and see if the phone works as the new ones can be faulty.
If this wont work there are problems on the main board, it will good to check the adapter and the voltage at the battery terminals.
Hello, After charging my Peak 300 Jump Starter it whistle's (loudly) after I unplug it and it just keeps whistling... Can you tell me what the matter? email:
Refer to the instructions that came with charger. If you threw them away you have a problem You can go on line and download instructions.
Low Charge Alert (LCA)
On the front of the unit there is a Low Charge Alert port. There is a red plug in this port. With the plug
removed, when the battery level drops to LO, an alarm will sound to remind the user to recharge the
Jump-Starter.
The alarm can be turned off one of three ways:
Placing the pin back into the Low Charge Alert port
Recharging the battery immediately to bring it to the capacity of 10% or more
Pressing the battery indicator display button. If the alarm is turned off by pressing the battery
display button, the alarm will sound automatically again in approximately 1 hour.
The alarm will only be turned off permanently if the battery is in a fully charged state, or the pin is
inserted in the Low Charge Alert port. There is a storage port on the back of the Jump-Starter for the
LCA plug. When the plug is removed from the LCA port, it should be installed in the storage port on the
back of the Jump-Starter.
Charging Jump-Starter Battery
All rechargeable batteries gradually discharge when left idle, and you need to recharge them
periodically to maintain maximum battery capacity. The AC charger plug within the Jump-Starter is
designed to charge using a 110/120-volt outlet.
Fully charge unit to the recommended maximum and initial charge time of 24 hours. Thereafter, an
AC typical charge time is 8 to 12 hours.
Recharge the unit fully after each use. This will prolong the life of the battery because frequent
discharges between recharges will reduce battery life.
Make sure all functions of the Jump-Starter are turned off during recharging
3helpful
I have a new Nordik digital indoor timer TD133B. It has never displayed information on it's screen. The instruction manual indicates plugging it in for an hour to charge the battery. I did this but still...
Most plug-in timers have rechargeable battery that is not replaceable.
Instructions say: Plug in timer for hour and then unplug it to set programs.
Intermatic makes a couple plug-in outdoor timers with replaceable batteries that load from back of timer, but otherwise batteries are rechargeable.
If battery will not charge, then display doesn't show, and that signals the timer is no good.
Take timer back if you can, and exchange for another.
I was looking at timers in Walmart and Target yesterday (since my specialty, and interest is timers).
New plug-in timers are inexpensive.
Lowes and Home Depot also carry inexpensive plug-in timers.
Be sure to save timer instructions because generally, store-bought timer brands don't show manuals on-line. Except GE brand timers from Home Depot.
Add a comment if you need more help.
http://waterheatertimer.org/Woods-timers-and-manuals.html
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
1helpful
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
5helpful
Display battery level
Well, I tried pressing and HOLDING down the mode button. The battery level display miraculously showed up. I’ve also read (yahoo answers) that battery level display will show up automatically when battery is low. Hopefully I won't have to do this every time I recharge the battery.
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Model LXT 300 FRS/GMRS RADIO
There could be three (3) reasons why the display shows the battery icon at the top left side of the LCD display:
1. weak/undercharge/discharge batteries;
2. dirty/corroded/loose battery contacts/terminals; and/or
3. internal fault with the electronic sensing for battery level/state.
Corrective measures would require:
a. replace/recharge batteries. The rechargeable batteries need at least 12 hours of charging time;
b. clean, scrape, tighten (need to bend a little more towards the battery terminals) the spring/contacts of the battery holder;
c. (on the internal fault) your best bet might be to seek the services of a professional electronic technician since this would need familiarity with electronic components, their circuitry and diagnosis, perhaps a bit of soldering and the use of a DVM.
On the other hand, if the "low" is the "L" icon at the bottom right side of the display, this would indicate that the radio's transmit power setting (H/L - high/low). Transmit power level can only be changed in Channels 1-7 & 15-22. The radio will also auto change to lo power when batteries are weak.To switch to high power, press on the Menu button thrice or till "Pr" icon shows, press on the up/down to select H or L. To save & exit, momentary press the PTT.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
3helpful
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
1helpful
2answers
Phillips CD235
Hi try using
0000 this is the default pin number
Top Philips Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Philips Cell Phone Expert? Answer questions, earn points and help others
