20 Most Recent Woods Indoor 24 Hour Digital Timer (59203) Questions & Answers
TD1000 manual
Add a comment if manual is incorrect
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Woods timers and manuals including TD1000 appear on following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Woods Indoor 24... | Answered on May 16, 2017
I have never seen the electronic schematic... but instructions are on following link among the old manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Woods Indoor 24... | Answered on Mar 02, 2016
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
These timer are often non-functioning form the beginning, or go bad short time later. Other timers last a few years.
Gene
Water Heater Timers Save Money
Woods Indoor 24... | Answered on Jan 08, 2015
Link might have correct manual
Gene
Woods Indoor 24... | Answered on Dec 12, 2014
Copy following link to identify timer and download possible manual:
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Woods Indoor 24... | Answered on Aug 08, 2013
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Copy following link to identify timer and download possible manual, showing 1 year limited warranty:
Add a comment and describe brand, type and model of product.
Also say if this is new installation or older installation
Woods Indoor 24... | Answered on Apr 26, 2013
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Woods Indoor 24... | Answered on Jan 07, 2013
I cannot find TM 020.
TM is a Woods timer prefix.
Many Woods timers have more than 1 number depending on who packaged and sold timer.
You might be able to recognize timer from the photos shown on link below.
Following page has Woods timers and manuals.
Woods Indoor 24... | Answered on Jun 09, 2012
Question posted under oval-shaped programmable timer.
There are several oval-shaped plug-in timers.
Open following link to identify timer.
Typical manual for oval-shaped timer may apply to your timers:
If this is not your timer, then add a comment and describe timer in detail.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Woods Indoor 24... | Answered on Sep 19, 2011
I have not heard of Woods 59732
You posted next to a photo that shows Woods 49063
Woods has many different numbers for same timer.
Manuals show for each timer on page
Woods has 59730 yard stake:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
Other pages you can look at to identify your timer:
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Add a comment for more free help, and say what buttons appear on timer.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Woods Indoor 24... | Answered on Aug 03, 2011
For digital timer:
1) Timer is defective
2) Conflicting programming so timer does not perform as expected
3) Timer not set to correct mode.
4) Program 'off' is set correctly, but program 'on' is not set or 'on' time conflicts with other programming.
5) Current time not set correctly
6) Polarity on outlet is reversed or noise on the line. Check outlet with circuit analyzer.
7) Combination of factors listed above
Woods Indoor 24... | Answered on Jun 26, 2011
Woods Indoor 24 Hour Digital Timer (59203) Logo
51 questions posted
Top Woods Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Woods Hardware & Accessories
Most Popular Question
set clock using 24 hr 12 hr clock
  • Hardware & Accessories
