Washing Machines Logo
Posted on Mar 26, 2011
Model W752, need drain hose - model is discontinued
Need an Electrolux agent in Alberton, SA. Need rubber seal for my vacume cleaner
picture is of the v cleaner unit with that model number
cant find a listing that hose seal as such
the hose with the seal as a whole.. is now discontinued
try looking for a used unit or improvise
Where is the radiator drain valve located on 2007 GMC Acadia SLT FWD?
No More Radiator Drain Valves in GM vehicles
0
Starting in 2003, GM discontinued the use of a drain hose attached to the radiator drain valve. Later, GM discontinued the use of a radiator drain valve altogether. Some models continued to include a drain valve, but the valve was permanently sealed during production. Do NOT try and operate these sealed valves-they will break. GM warns that if you try to remove and replace the valve, debris from the breakage may circulate throughout the system and damage water pump, heater core, and thermostat components.
The bottom line is that you must now either remove the lower radiator hose or use a siphon to remove coolant from the radiator. This bulletin applies to all 1998-04 GM cars and trucks.
1helpful
I have an whirlpool gold ad50gpusb from canadian tire. The pump will no longer pump via the clear rubber hose and instead the water accumulates in the bucket. Do you know if there is a simple fix to...
For the others who follow
I have the same model, same problem on a 2 year old purchase made in 2014. This unit has a pump (and a hose) to drain the condensate.
The pump light started blinking about a week ago, turning cycling power worked for a while, until pumping stopped altogether.
After investigating:
-the hoses are not blocked but there was some algal growth in the tray which I cleaned
-the pump no longer pumps.
-my favorite parts suppliers and other on-line sources have no record of the model/parts etc.
-Called "whirlpool" consumer line in manual
-Whirlpool has been purchased by Garrison and that company has no parts for this discontinued model but did provide a phone number for the pump 800-799-0991. Unfortunately the cost of this small solenoid pump is $74.
I will drain the condensate via gravity to a floor drain as I don't see spending that much for something that broke so quickly and appeared poorly made..
Bosch shu43c02uc
test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 • Dishwashers
I have an LG energy star auto start dehumidifier (about 3 years old). It works fine. How can I hook it up to drain into my laundry sink automatically? It would save me the effort of emptying the bucket...
Unfortunately, draining into a laundry sink is not an option. As your model does not have a pump, it relies entirely on gravity to drain with a 48" length of garden hose. A floor drain is the perfect way to go, if you have one.
To further assist you, I have included a llnk to your model, which has been discontinued. You can download and print the manual for future reference if you like.
Hope this helped you and thanks for choosing FixYa.
I got a danby ,and i not no how to use it. there is hole at the back of it, but i do not a hose,what do i do
Unfortunately, the model have has been discontinued. The hole on the back is for an exhaust hole for an exhaust hose that goes out a window. However, there is more to it than just the hose. You need the hose couplings/connectors and the window termination kit. Even though your model has been discontinued, Danby may be able to help you. 800-496-6049
Hope this helps you solve the problem. Please let me know. Thanks.
3helpful
With this model is there a way to attach a hose to it so that I can leave it running continuously while the hose is draining into drainage hole in my basement? m7dh65b2a
Yes, there is a way to do it. As a matter of fact, your model (now discontinued) came with a short section of hose. However, you can still use a short 5' section of garden hose and achieve the same results. To find the hose connection (if you don't have your Owners Manual) remove the bucket and you should see what looks like a hose connection (which it is) behind where the bucket sits in the unit. If it is not there, inspect the back of the humidifier for a small 2"x 2" pop-out compartment door. Inside of that is the hose connection. Remember, dehumidifiers do not have pumps to pump the water out, they rely on gravity for water to flow through and out of the hose.
Hope this helped you. Please let me know. Thanks
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
6helpful
Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
1helpful
Missing the drain hose connector
A drain hose is a drain hose, go to home depot and get the dimension and lenght you need.
Top Avanti Washing Machines Experts
Kolbrun...
john h
Jorgie  the...
Jorgie the...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
