SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
SOURCE: Samsung NV10 Charging problem
I had the same problem while charging the camera with the cradle. I tried charging directly with the camera and it looks good. Problem seems to come from the cradle itself. Phil
SOURCE: When charging my camera the charger light flashes
battery issue try changing the batt they are not taking the charge pls replace if they got weaken or aged
pls rate me fixya if it helped
SOURCE: praktica slimpix battery doesn't charge,usb
That is correct. The camera does not recharge the batteries. If you are using rechargeable batteries then you also need a compatible battery charger for the batteries you are using.
