Microwave Ovens Logo
Posted on Mar 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our lower level oven does not heat up. The convection oven. A code of Fr shows. What Gives. The top oven is working fine. I have replaced the entire touch pad previously. We have a Jenn-air 30"Expressions Convection Wall Oven Model WW30430. Thanks Folks
Anonymous
Level 3:
Genius:
  • Master 1,196 Answers
  • Posted on Mar 24, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1196
Questions
0
Helped
209702
Points
3559
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the oven back into the wall power supply to reset any anomalies with the oven memory. see what happens.
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
2answers
No heat generated in microwave or convection oven mode
I just read that starting the microwave as usual and then slightly pressing in the handle (you can hear the heater(?) come on will make the heat come on. Tried it and it works. My repairman told me it needed a new magnetron ($700) but that was totally wrong. I will be trying another repairman to replace handle mechanism.
Jennair JMC9158AA microwave not heating consistently - turntable moving, fanblowing - sometimes heats convection oven feature still working fine
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
I cleaned our oven, and now it is not heating up. The convection oven works fine, but the microwave will not heat. It comes on fine, but doesn't cook. What are the possible solutions?
Basic Microwave Oven Troubleshooting Tips
heatman101
Microwave heating not working. convection is fine
Therer could be many causes for this and will need to be looked at by a qualified repair tecnician, I would suggest that you ask for a quote first as the repair could be simple of very expensive.
Hope this helps
My kenomore Microwave has pwer and has stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
0ut
2answers
Sharp microwave model #1872
Most likely the lower door interlock switch is bad. Cheap and pretty easy repair.
Martin Microwave Inc. sells the switches for around $5....
www.martinmicrowave.com
1helpful
Amana ACE208 doesn't work with a message 'door'
The door latch receiver has a spring action lever (inside) that is made out of plastic and cracks or wears through. You need to remove the cover and remove the two screws holding the door latch receiver. Now you can switch the top and bottom piviot switchs, putting the top one lower and the lower one on top..make sense? you"ll understand when you see it.
1helpful
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
