Hi stanleywms, "Highlight" the item you want to (Enable) this being the "Pointer Device." Click on the [Enable] button. Be sure to (Click) on the "Apply, and OK buttons" "You may need to "Update Drivers?" Next in the "Mouse Properties" (window). Open the "Properties," Now, open the [Driver] by [2x clicking] on it." If the, Update Driver (block) is not "Grayed-out?" Click to "Update Driver", and click the (OK) button. "To Manually" Install Driver Select to "Update Driver." Next, select: ("Browse my computer for driver software"). Now, choose: ("Let me pick from a list..."). Click on the "Settings" button "Try out some of the "Items listed" ->-> Important: "Take a 'moment to rate the help', so I can get 'credit' for the work. Thank you!" - paul7of9
Click on the "Start Button."
"In the (right area), select to open the Control Panel.
Next in the [Hardware and Sound] category.
"Choose the "Mouse" 'applet.'
Next, click on the"Device Settings" in the (Devices) block.
"Open the "Device Setting:
*Tapping, *Virtual Scrolling...
" "Apply" button after each change!
This 'comment' is for FixYa! So my understanding is; -10 is {subtracted} for "Not Helpful: Solutions!" But! When the "Solution is Very Helpful! = 5 or < LESS!" ? Is this "Correct"!? I have another ?Question? Do a number between a (100 to 1000) people respond quicker, and more to "Solution that do not help!" In comparison to the "Solutons that do?"
There will be a dedicated key to enable your mousepad. You can also restart your computer to reset the settings and enable it.
"Please Post back to let us know if we helped.Kindly rate this article"
In some Compaq, there is a switch on top of it. Try to press that button and check if it will work.
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
