SOURCE: canun digital camera powershot A630 lcd screen blank
I also cracked my Canon Powershot A630 lcd screen by dropping the camera. I saw a suggestion to buy a new replacement lens and either have it professionally replaced or try it myself. I ended up doing the replacement myself following instructions I found online. Now it works. Total cost US $63.
I would not recommend trying the replacement yourself, however. There are a few very delicate plastic parts in there which I ended up damaging. Luckily the camera and lcd screen are working great now. But it is probably worth having a professional camera repair shop do the whole job or insert the screen you've purchased. Good luck!
SOURCE: Problems viewing Hi8 tapes
Seems video head of your handy-cam is dirty or clogged. Use good quality video head cleaning tape to clean video head.
SOURCE: Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
SOURCE: Geko 101 wouldn't turn off. Removed/inserted batts, wont turn on
Press the power on button while holding OK until the unit switches on- that puts the 101 into Service mode. Then press the up key until the screen contrast is about right. (or press the down key... to make it darker). You'll be able to see if all the tests pass. Then when you're happy with the setting, turn off.
SOURCE: DRYER SCREEN IS FLASHING 8888
I turned the breaker off and then on again and all was solved, my dryer was back to being normal again.
