Hello, ramrodsc2 Removal Procedure 1. Drain the cooling system untilthe coolant is below the level of the water pump. 2. Remove the drive belt guard. 3.Loosenthe waterpump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulleybolts and remove the water pump pulley. 6. Remove thewater pump bolts then Remove the water pump. 7. Remove the water pump gasket 8. Clean the water pumpmating surfaces pay particular attention to the cleaning process and make surethe surfaces are clean. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump; tighten the bolts to 10 Nm (89 inchlbs.). 3. Install the water pump pulley.Loosely install the mounting bolts. 4. Install the drive belt; this will help hold the pulley thentightening the pulley bolts. 5. Tighten the bolts to 25 Nm (18 inch lbs.). 6. Install the drive beltguard. 7. Fill the cooling system. 8. Inspect the cooling system for leaks. Regards, netvan
For
complete water pump replacing procedure, step by step, there are few help
links.I suggest you to refer the help links.
Click
the link below:-----
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
These
will help.
Thanks.
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
How to route Water Pump Belt for 1992 Oldsmobile ?
How to replace Water Pump on Car ?
How to Remove Water Pump?
Where is Water Pump located ?
This will help. Thanks
provided below.
provided below.
This will help. Thanks.
provided below.
provided below.
provided below.
provided below.
How to route Water Pump Belt ?
provided below.
How to route Water Pump Belt?
