Heating & Cooling Logo
Posted on Mar 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our home is equiped with a Nordyne E2EB-015HA furnace. I noticed and exteme amount of heat coming from th unit. when we pulled th cover off, the area behind the "blower blades" was red hot. What is the problem and how do I fix it? I shut off all breakers
Michael Ulch
Level 2:
New Friend:
  • Expert 48 Answers
  • Posted on Mar 13, 2011
Michael Ulch
Expert
Level 2:
New Friend:
Answers
48
Questions
0
Helped
16694
Points
134
Intertherm electric furnace model E2EB-015HA. Upper element will come on and run continously in 20 degree temp, Lower two elements don't come on. What's up?
Sounds like one or 2 stages of the sequencer is not kicking the other elements on. -OR- the limits ie klaxon switches in series with your elements are stuck open.
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
2answers
I have a heating furnace problem. I need a wiring diagram for the model FEHB-015HA. We had to replace the heating elements and when we tried to hook the wires back up, the white connector(full of wires)...
Hello, Namalee -
I find that the Nordyne brand is what is called a "legacy brand" owned by Nortek Global HVAC.
https://www.nortekhvac.com/
That means Nortek owns the brand name and nothing is currently manufactured with the Nordyne name.
I have looked through the Nortek Global HVAC web pages and have not found any source for a wiring diagram for your model Nordyne furnace.
I suggest you telephone the company (headquaters in O'Fallon, Missouri - Central Time zone) and ask if the company can provide you with a wiring diagram or direct you to a reliable source for it. This is the toll free phone number I found on the Nortek website:
800-422-4328
2helpful
Fan will not turn off
With your breaker on, the system selector switch (at your tstat HEAT/COOL/OFF) in OFF and the Fan Switch (ON/AUTO) in the AUTO position, Trace the wires from the Blower Motor to the blower relay. Try tapping gently on the relay using the plastic handle of your screwdriver/nutdriver. If the blower shuts off, the blower relay is sticking and needs replaced. Fortunately, this is a problem that will allow for the system to continue to control the temperature while you are awaiting your new part to arrive.
This is the problem for 90+% of the problem you are describing. If this does not resolve your problem, let us know and we'll look into another area.
Good Luck in your endeavor! :-)
Blower motor doesnt always come on in heat mode
Yes if your creful. There is a sequencer inthe unit that operates the fan in the heat mode. It sometime sticks. This is due the moisture from the ac sweating. You van pick upa sequencer at HVAC parts house. Just wire back wire to wire and you willbe ok. Kill power to furnace first. Rus
7helpful
3answers
Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Top Heating & Cooling Experts
Paul Carew
john h
