My nordyne furnace model e2eb-015ha heating elements come on in between cycles without fan and does not turn off
Posted by Allen Tittle on
Brian Mills
    Master:
  • 613 Answers
Between which cycles, defrost ?
Posted on Dec 17, 2013
1 Related Answer
laura Newman
  • 415 Answers
SOURCE: fan will not turn off
With your breaker on, the system selector switch (at your tstat HEAT/COOL/OFF) in OFF and the Fan Switch (ON/AUTO) in the AUTO position, Trace the wires from the Blower Motor to the blower relay. Try tapping gently on the relay using the plastic handle of your screwdriver/nutdriver. If the blower shuts off, the blower relay is sticking and needs replaced. Fortunately, this is a problem that will allow for the system to continue to control the temperature while you are awaiting your new part to arrive.
This is the problem for 90+% of the problem you are describing. If this does not resolve your problem, let us know and we'll look into another area.
Good Luck in your endeavor! :-)
Posted on Mar 03, 2010
Intertherm electric furnace model E2EB-015HA. Upper element will come on and run continously in 20 degree temp, Lower two elements don't come on. What's up?
Sounds like one or 2 stages of the sequencer is not kicking the other elements on. -OR- the limits ie klaxon switches in series with your elements are stuck open.
Dec 08, 2013 | Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Model e2eb-015ha elements cycle on and off, but blower motor never comes on;a/c side works fine
R u saying that the blower motor works for the AC but not for the heat. If thats the case then u have a t-stat or control board problem. u can jump the red white and green wire from the tstat. if that works then then tstat needs to be replaced if not the control board is the problem.
Oct 21, 2011 | Intertherm P3RA-048K Air Conditioner
I have a heating furnace problem. I need a wiring diagram for the model FEHB-015HA. We had to replace the heating elements and when we tried to hook the wires back up, the white connector(full of wires)...
Hello, Namalee -
I find that the Nordyne brand is what is called a "legacy brand" owned by Nortek Global HVAC.
https://www.nortekhvac.com/
That means Nortek owns the brand name and nothing is currently manufactured with the Nordyne name.
I have looked through the Nortek Global HVAC web pages and have not found any source for a wiring diagram for your model Nordyne furnace.
I suggest you telephone the company (headquaters in O'Fallon, Missouri - Central Time zone) and ask if the company can provide you with a wiring diagram or direct you to a reliable source for it. This is the toll free phone number I found on the Nortek website:
800-422-4328
Jan 12, 2018 | Heating & Cooling
Fan will not turn off
Mar 02, 2010 | Heating & Cooling
Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Apr 11, 2009 | Heating & Cooling
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
Heating & Cooling Logo
498 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
