To remove first you want to remove the headlight door mounting screws and remove the headlight door. Then you want to remove the 4 retainer ring screws and remove the retainer ring from the headlight. Then you want to pull the headlight bulb forward and detach the wiring connector.
To install you first want to attach the wiring connector to the headlight bulb and place the bulb in position, locating the bulb glass tabs in the positioning slots. Then you will attach the bulb retainer ring to the assembly with the retainer ring screws. Then you will install the headlight door and secure with the screws. Then you will check the headlight bulb aim and adjust as necessary
Let me know if this helps you.
