Maytag MER6772 Gemini Electric Kitchen Range Logo
Posted on Mar 03, 2011
How do I remove the upper ovens bake element?
bryant
Level 1:
  • Contributor 53 Answers
  • Posted on Mar 22, 2011
bryant
Contributor
Level 1:
Answers
53
Questions
10
Helped
12807
Points
86
There is a plate on the back wall, inside the oven. Take the screws out that hold that plate on . next take theelement out of its clips and pull the element gently towards the front of the stove. You dont have to move it very far and you will see the wires on the ends of the element. They are held on the element with screws. Loosen them and remove element. Reinstall new element in reverse order and make sure not to push insulation back too far. PLEASE TURN BREAKER OFF AT PANEL OR UNPLUG STOVE FIRST Hope this helps you out Good luck!!
1 Related Answer
Anonymous
  • Posted on Feb 09, 2008
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
1helpful
Built-in electric oven jtp15w2ww gets to temperature then quits. No error codes.
If your built-in electric oven is getting to temperature and then quitting during a bake cycle, and the upper heating element is not working during the bake cycle but works on the broil setting, it is possible that the problem is with the bake element. Here are some troubleshooting steps you can take:
  1. Check the bake element: The bake element is the heating element located at the bottom of the oven. To check if the bake element is working properly, turn on the oven and set it to bake mode. Open the oven door and look at the bake element. It should be glowing red. If it is not, then the bake element is likely faulty and needs to be replaced.
  2. Check the oven temperature sensor: The oven temperature sensor is a small probe that is located inside the oven. Its job is to monitor the temperature inside the oven and communicate that information to the oven's control board. If the sensor is faulty, it may cause the oven to shut off prematurely. You can test the sensor with a multimeter to see if it is working properly. If it is not, then it needs to be replaced.
  3. Check the oven control board: If both the bake element and the oven temperature sensor are working properly, then the problem may be with the oven's control board. The control board is responsible for controlling the oven's heating elements and other functions. If it is faulty, it may be shutting off the oven prematurely. In this case, the control board will need to be replaced.
It is recommended to hire a qualified technician to perform these tests and replace any faulty parts to avoid any risks of electrical shock or damage to the oven.
Nov 23, 2022 • Ovens
Oven only lights from the bottom
BUTTOM ELEMENT CALLED "BAKE" ELEMENT, UPPER CALLED "BROIL" ELEMENT ---> SO IF YOU USE "BAKE" BUTTOM COMES ON; IF YOU USE "BROIL" , UPPER COMES ON :)
GLEB30T8CSA upper oven baking element has no power
It may be you have a bad element. If you remove it and have a volt meter you could check a the socket for power. Also if the upper and lower elements are the same change the working one to the upper oven and see if it works. If it does you need to purchase a new element. If there is no power to the upper oven you may have a bad control ora broken wire behind the panel. I would advise you to turn off the power to the oven before pulling or changing any componets.
Whirlpool double oven, bottom oven not heating
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
1helpful
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 • Ovens
Oven takes 20 minutes to fully heat on bake - Kenmore oven plt095-2
if its a gas model most of the time you will have a weak oven ignitor. if an electric,check to see if the bake element gets hot ,some ovens will bake with upper and lower elements so if only the upper works it will take much longer to pre-heat.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
3answers
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Fef369cgsd frigidaire oven
What do you mean by, "properly"?
Is it heating or not at all?
Is it not hot enough, or too hot?
Upper element is for broil. It may come on briefly during bake, but usually at half power. It doesn't glow red.
Does the bottom element glow red? If not, inspect lower element, which is the bake element, for pits and rough spots. These may be signs of failure.
UNPLUG STOVE!! Remove bake element and check for continuity. If it shows open, replace. You can probably take to parts store and they can test it for you.
2answers
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
