"Aero features are'nt running in window's 7"
Solution: Check that your computer meets the minimum hardware requirements for
running Aero:
1-gigahertz (GHz) 32-bit (x86) or
64-bit (x64) processor
1 gigabyte (GB) of random
access memory (RAM)
128-megabyte (MB) graphics card
Aero also requires a DirectX 9 class graphics processor that
supports a Windows Display Driver Model Driver, Pixel Shader 2.0 in
hardware, and 32 bits per pixel.
For best results, you might also
want to follow these graphics processor recommendations:
64 MB of graphics memory to support a single monitor with a resolution
that is less than 1,310,720 pixels (for example, a 17–inch flat panel
LCD monitor that has a 1280 × 1024 resolution)
128
MB of graphics memory to support a single monitor with a resolution from
1,310,720 to 2,304,000 pixels (for example, a 21.1–inch flat panel LCD
monitor that has up to a 1600 × 1200 resolution)
256 MB of graphics memory to support a single monitor with a resolution
greater than 2,304,000 pixels (for example, a 30–inch wide-screen flat
panel LCD monitor that has up to a 2560 × 1600 resolution)
To turn on window frame transparency, the color scheme must first be
set to Windows Aero.
1.Open Personalization by clicking the
Start button Picture of the Start button, clicking Control Panel,
clicking Appearance and Personalization, and then clicking
Personalization.
2.Click Window Color and Appearance.
3.Select the Enable transparency check box.
To change the color scheme to Windows Aero
1.Open Appearance
Settings by clicking the Start button Picture of the Start button,
clicking Control Panel, clicking Appearance and Personalization,
clicking Personalization, and then clicking Window Color and Appearance.
If the Appearance Settings dialog box is not displayed, at the bottom
of the page, click Open classic appearance properties.
2.In the Color scheme list, click Windows Aero, and then click OK.
Check that your theme is an aero theme and not a normal theme. Themes
are available in normal and aero and can be confusing. Set your theme as
an aero theme and you should get the aero window working.
These
steps will help us to have AERO running.
Thank's and Regard's:
Pcs365.8
Can you post the exact error that comes from loading a DVD into the drive? Or is it even reading the DVD? If it doesn't read a DVD will it read a CD?
