Anonymous Posted on Mar 02, 2011
Every time I open a folder on the desktop, I get a small windows installer window asking "Insert SmartWebPrintingOC disk and click OK". After I click cancel three times, this window goes away and the folder opens. And this happens with every folder I open from the desktop. How do I get rid of this smart web printing prompt ? Thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Mar 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
7363
Points
73
I'm guessing you may have an HP printer. I have seen this happen quite often. For some reason a piece of the HP software goes haywire and wants to re-install itself.
The best method I have found is to remove all the related HP software that was installed with your printer, restart your computer after all HP software has been removed and re-install your printer software. This will take care of most of these issues.
Sony VAIO VGC-RB38G PC Desktop needs the media center re-installed
I would seriously doubt that your kids know how to remove Media Center. Maybe they just removed the icon from the desktop. Click Start/My Computer and open the Local Disk C. Look for the Programs File Folder. If you are using Windows 7 or Windows Vista there might be two Program File folders (Program Files and Program Files (x86). Look thru the program files folders for the Windows Media Player Folder or Windows Media Center Folder. Open the folder and look for the Media Player. When you see the Icon you can Right Click on it and select Properties. If the Type of File in the properties windows says Application, that is probably the program that runs. You can close the properties window and double click on the icon and see if it runs.
If it runs, you can close it and go back into the folder and Right Click on the icon and select the option Sent To then select Desktop (create Short Cut). Right Click on it again and select option to Pin To Start Menu.
If you just want to download and install it again.
Get onlineand got to www.google.com In the google search box type: "Download Media Player" or "Download Media Center" (without the quotes). Select a site from Microsoft that will download and install it.
tip
How to do Fast and unattended Setup of OS in multiple machines
<span> <p><span>Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement.</SPAN><br> <p><span> </SPAN><br> <p><span>Verify for unattended Installation:</SPAN><br> <p><span><span> </SPAN>To perform an unattended installation from a CD-ROM, the following conditions must be met:</SPAN><br> <p><span>The computer must support booting from a CD Rom<span> </SPAN>The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.</SPAN><br> <p><span>The answer file must contain a valid [Data] section. This is explained later in this article.</SPAN><br> <p><span> </SPAN><br> <p><span>Before installation it has some conditions:</SPAN><br> <p><span><span> </SPAN>1&gt; the installation is limited to a single partition.</SPAN><br> <p><span><span> </SPAN>2&gt; you cannot specify third-party drivers during Setup </SPAN><br> <p><span> </SPAN><br> <p><span>Prepare For an Unattended Installation:</SPAN><br> <p><span><span> </SPAN>To prepare your computer for an unattended installation from a CD-ROM, I've followed these steps</SPAN><br> <p><span>First I've created a Folder in local drive & shared it. Then I create setup manager.</SPAN><br> <p><span>I install Setup Manager by following these steps:</SPAN><br> <p><span>I Open My Computer, and then open the Support\Tools folder on the Windows XP CD-ROM.</SPAN><br> <p><span>Double-click the DEPLOY.CAB file to open it </SPAN><br> <p><span>On the Edit menu, click Select All.</SPAN><br> <p><span>On the Edit menu, click Copy to Folder.</SPAN><br> <p><span>Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.</SPAN><br> <p><span>Click Copy.</SPAN><br> <p><span>Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows Setup Manager Wizard starts.</SPAN><br> <p><span></SPAN> <br> <p><span></SPAN></SPAN> <br> <img src="alokerdas_9.jpg"> <br> <p><span>Then I Use Setup Manager to Create an Answer File.</SPAN><br> <p><span>I open the setup manager & go to create a new answer file.</SPAN><br> <p><span>Then I go to the unattended installation & windows version option.</SPAN><br> <p><span>I have selected the fully automated option & create an answer file.</SPAN><br> <br> <br> <img src="alokerdas_10.jpg"> <br> <p><span>If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"</SPAN><br> <p><span>If you omit this line, you are prompted for the installation partition.</SPAN><br> <p><span> </SPAN><br> <p><span>Add a [Data] section with the following entries to the unattended answer file:</SPAN><br> <p><span>Unattended Install=Yes - Value must be set to "yes"</SPAN><br> <p><span>MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup<span> </SPAN></SPAN><br> <p><span>Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.</SPAN><br> <p><span>Save the unattended answer file as Winnt.sif on a floppy disk.</SPAN><br> <p><span>Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.</SPAN><br> <p><span>Change the boot order in the CMOS so that the CD-ROM is first in the list.</SPAN><br> <p><span>Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.</SPAN><br> <p><span> </SPAN><br> <p><span>This is an easy process to save time & effort.</SPAN>
on Feb 15, 2011 • Computers & Internet
tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 • Computers & Internet
Need the window media center re-installed
Hii..I Am Having An Acer Aspire 5050...Well I Installed Windows Vista Ultimate On It But Originally It Was Windows Visa,Therefore,After Installing Windows Vista Ultimate I Tried To Upgrade The...
If you place your Win7 disk in the DVD drive boot the laptop from the disk and choose to install a new system.
Follow the menu and prompts.
When it has installed download the drivers from Acer.com otherwise you will get problems.
Hope that helps.
3helpful
I have a Pfaff 2170 with a USB connection to my PC. It won't run using either Windows XP or Windows 7. I ran a fix hardware check--the computer does recognize it has something new plugged in, and the...
If you have the original 3D file manager disk, the drivers are on there. In XP, With the sewing machine unplugged from the computer, insert the disk in the cd drive and explore the disk. Copy the "drivers" folder to your desktop. Plug in the Pfaff 2140/2170 to the usb port. Windows will ask for a driver disk. browse to the drivers folder on your desktop and open it, windows will highlight the driver it needs and click "OK". This worked on my wife's 2140 upgraded to 2170 software and you must always use the same usb port, or go through this routing again.
2helpful
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
1helpful
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
4helpful
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
k24674
ADMIN Andrew
ADMIN Andrew
