E-Machines T2885 PC Desktop Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't open control panel on my T2885 Emachine
Anonymous
Level 2:
New Friend:
  • Expert 153 Answers
  • Posted on Mar 01, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
153
Questions
0
Helped
36996
Points
491
Have you tried restarting the computer? Hope this helps =]
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
3346
Points
59
Sounds like you need to run anti-virus, and possibly reinstall your Operating System.
Have an emachine T2885 took side panel off to clean put back on now no power. and there is no switch in back so i couldnt of turned it off
Nothing serious, sounds like you may have accidentally disconnected some of the wiring by accident while wiping the dust away! Just reopen it and check what's unplugged in the system. - Hope that helped =]
2answers
Emachine t2885 won't start. the power supply and fan works, but the o/s would not come up. any suggestions? thanks
When your system boots Hold F8. You will find list of commands. Try the last known good config and then restart the system once done.
Emachine wont start up
This is a DESKTOP machine, not a laptop. It has to be plugged into a wall outlet that has power, for the machine to run.
1helpful
Emachine T2885 won't start up after I cleaned it with vacuum
unplug and remove the ram and battery remove the jumper on the clear mos for 5minutes Put everything back together make sure everything is seated firmly
1helpful
Need to remove fromt panel from t2885 machine
First of all, disconnect the power cable from the electrical outlet and from the back panel. Then
disconnect any cables connected to the computer.
here is the link to the pdf file (including pictures) of how to remove the face ..
http://downloads.emachines.com/userguides/Desktop_UG_Nexgen2_3_en.pdf
this require adobe reader (free) if you dont have it already. refer to pages 4-7 to 4-11 for the info your looking for.
1helpful
Emachine t2742 I also have a wiring problem!
gtater,
It's ironic that you ask me this question today-- i am just now carrying in another eMachine computer to fix. Anyway, unfortunately I do not have one that is the same model as yours (T2742). However, I did some quick research and found that yours has the same exact motherboard as the T2898 which I made the diagram for!
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
For further reference, I would like to share this diagram for the eMachines T6544 in case someone else may need this model. This is the computer I just carried in... might as well share.
By the way, the power switch doesn't need to be oriented any particular way (positive and negative), which is why the switches are not labeled as + or -. Switches can be wired either way and they will work the same.
Hope this helps.
2answers
D845EPI/D845GVSR Mobo from T2885 emachine
Use the master and slave funcition by purchasing a new double sata cable
1helpful
I'am geting an error message tellinf me my printer spooler subsystem app has encounter aproblem and need to close.and this is causing my printer not to work, can you help me with this problem i have a...
if you have the disk that came with the printer you need to uninstall it and reinstall it , or check your cables from the back of the printer to the tower and make sure they are connected , see if that helps solve your problem most likely you will have to uninstall and reinstall the printer
2answers
Wiring diagram for T2885
Give me also model serial number (printed on your motherboard or on seller's receipt).
http://www.dealtime.com/xPF-E-Machines-Desktop-with-Intel-Celeron-Processor-2-8GHz-T2885
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
