Hi
to activate the wifi switch it is i believe it is down of the left front of the laptop actually on the front of the laptop itself and normally a slide switch which needs to be pushed over to the right before it will activate
loud speaker icon depending on which operating system your running
if you are on windows 7 look over to the bottom right handof your screen if you cant see the audio
icon that looks like a loud speaker
can you see a upward facing arror
if so click on that arrow then click customize then go find the volume icon and click show icon
and notification
if on xp try this
start
settings/control panel
audio/sound
somewhere in there you should be able to tell it to show in taskbar
good luck
If
your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen
wont respond or in other similar ways doesn't perform as it should, this can
often be solved by performing a software update. Software may perform
incorrectly for many reasons without there being a fault in the phone. Some
problems may be fixed by re-updating your current software, while others may
require installing a new software version.
To
keep your phone performing at its best, it's a good idea to perform a software
update regularly. You might not always notice what an update has done, but it
can prevent future problems.
To
update or reinstall the software please go to nearest authorized service centre
of your mobile make and they will update or reinstall the software as required.
Note:
Reinstalling the software will delete all the content in your phone like
contacts, calendar entry etc.
Thank You
