The fuel pump relay on a 2019 Nissan Frontier is located in the engine compartment fuse box. The specific location of the fuse box can vary depending on the exact model and trim level of the vehicle, but it is typically located near the battery or near the driver's side fender.
To locate the fuel pump relay, open the engine compartment fuse box and look for a rectangular relay with a part number that begins with "25230". The relay should be labeled as the fuel pump relay.
It's worth noting that if you suspect an issue with the fuel pump or fuel system on your 2019 Nissan Frontier, it's important to have the vehicle inspected and diagnosed by a qualified mechanic to ensure that the underlying issue is properly identified and addressed.
The fuel pump relay on a 2002 Suzuki Esteem GL is located in the engine compartment, in the fuse and relay box on the driver's side. Here's how to find it:
Open the hood of your car and locate the fuse and relay box on the driver's side.
Remove the cover of the fuse and relay box.
Locate the fuel pump relay. There should be a diagram on the underside of the fuse and relay box cover that indicates which relay is the fuel pump relay.
Once you have located the fuel pump relay, you can either test it or replace it if necessary.
The location of the fuel pump fuse and relay on a 2021 Toyota Hiace van with a 1KD-FTV engine (model KDH223B) may vary depending on the specific model and trim of the van. In general, the fuel pump relay is likely to be located in the relay box under the hood of the van, while the fuel pump fuse may be located in the fuse box inside the van or under the hood.
To locate the fuel pump relay, you can try looking in the relay box under the hood of the van. The relay box is usually located near the battery or on the driver's side of the engine compartment. The fuel pump relay should be labeled in the relay box, or you can consult the owner's manual or service manual to identify the correct relay.
To locate the fuel pump fuse, you can try looking in the fuse box inside the van or under the hood. The fuse box is usually located under the dashboard on the driver's side of the van, or it may be located under the hood near the battery. The fuel pump fuse should be labeled in the fuse box, or you can consult the owner's manual or service manual to identify the correct fuse.
If you are unable to locate the fuel pump fuse or relay, or if you are having trouble identifying the correct components, it is recommended to consult a mechanic for assistance.
as far as i remember there should be relay box under the hood in the engine compartment and it should be labeled as what is inside and exact location on the lid. try that . if not there than look under the dash left side .
Having the fuel pump just replaced that morning doesn't mean that isn't the problem. Check it! The fuel pump relay is a good place to start though. The relay, and a few others, are in a box under the hood. Can't remember exactly where, but shouldn't be hard to locate. Try one of the other identical relays in the box (swap them) and see what you can find out.You need to answer a couple of questions. Is the fuel pump getting power/activating/working? Is the fuel pump getting fuel? The answers and the specifics around the answers lead to some other troubleshooting to try.
There is both a fuse and a relay for the fuel pumps electrical system. The image below of the Power Distribution Box is located in the engine compartment.
Fuse/Relay Location: 5 Fuse Amp Rating: 20 Amp Mini Fuse Power Distribution Box Description: Fuel pump
Fuse/RelayLocation: 203
Fuse Amp Rating: 1/2 ISO
Power Distribution Box Description: Fuel pump relay
go to pep boys or to an auto zone nd yo can use the computer which is available for public use most of thesse locations deal with mitchelle manuals and you can key in the year of your car and look under component locator guide (electrical) and you will see exactly where it is in your truck
