SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
SOURCE: samsung bluetooth handsfree password
SOURCE: connecting bluetooth head set
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold
the Multi-function button for 8 seconds, until >the lower half is lit up
blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you
want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter
passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
SOURCE: samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
SOURCE: Have a samsung finesse and i need help paring my
1- First turn on Bluetooth function on the Finesse.
2- Then start the pairing mode on the headset (for a Jawbone, make sure it is turned off then press the Noise Shield button for 3 seconds, the LED will begin to flash Red then White.
3- Back on your Finesse you should have the Bluetooth screen up with the search button in center, Press the Search button.
*the search & pairing process takes a minute or two, wait untill your headset finishes and stops blinking.
4- You should now show your Bluetooth device on your Finesse screen.
5- Now with your finger, Press,Hold and Drag the newly found headset icon onto the Search button in the center of screen.
6- A new screen will pop up then asking for the Passcode, enter: 0000 and press OK.
Your New Bluetooth Headset should now be linked to your Finesse. : )
