Question about Samsung WEP450 Bluetooth Headset - Retail Packaging
How to pair the samsung wep450 with another cell phone
Posted by theapache3 on
Altai r/s
    New Friend:
I have an Oukitel K6000 android phone, and had a same problem. I've read a few forums, but I knew that I didn't want to root my phone or use an app solving this. So I check my phone settings. And after I turn on the Settings/Sound and notification/Sound enchancement/BesAudEnh (Audio enhancer for earphone), the problem was finally solved. I hope I help others with same problem. It was simplier than other suggestion. =)
Posted on Jun 16, 2017
Dinesh Bajiya
    New Friend:
Samsung wep450 bluetooth headset
This device is connected all mob. device and all androids,
How To Connect: You Need first power off and after 5 sec. Power on button press 10 sec. continue, and this time search or refresh your mobile Bluetooth . and Connect .
Posted on Jan 06, 2016
3 Related Answers
ziraffa
chris grams
  • 827 Answers
SOURCE: I need the access code to pair it to my cell phone.
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
So - 0000 (four zeroes)
hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Posted on Dec 19, 2008
Anonymous
  • 497 Answers
SOURCE: How to pair up headset with cell phone?
first ul hav to press the button(big one) for a lil while..let the snap b closed...the light wud change to purple...then at the same time set ur bluetooth on the samsumg mobile to discoverable mode....snap open ur bluetooth and in ur mobile it will ask for a pass key which in default is 0000...then it will get connected
Thanks for using Fixya
keep me updated for further assistance
Posted on Jul 16, 2008
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: I can't pair my WEP410 with SonyEricsson Naite
To set the bluetooth please look at link below.
https://techtrain.samsungwireless.com/tekweb/Misc/Main/Accessories/WEP410_QSG.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on Mar 31, 2010
How do you connect a SAMSUNG WEP450 bluetooth to an ipod touch? Please get back to me as soon as possible. Your customer, Caleb Miller
Hi Caleb,Well, your headset is a monaural device, and, as such, is able to handle the 'Headset Profile' (HSP) and 'Hands Free Profile' (HFP) only, which are suitable solely for handling of phone calls. Your iPod is not a phone, though. It does support the 'Advanced Audio Distribution Profile' (A2DP) and the 'Advanced Audio/Video Remote Control Profile' (AVRCP). So, in order to pair a bluetooth headset with your iPod Touch, I'm afraid you'll have to buy stereo bluetooth headsets. You see, there are plenty of makers and models out there.
Really hope I'm not talking rubish here. Please, bear with me. I'm really getting old
Hope you are able to sort your problems out soon.
Best regards, Carlos
Apr 04, 2011 | Samsung Cell Phones
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Can't pair nokia 6790 w/samsung wep450 bluetooth there r no instructions in manual to show me the phone is picking up other signals
TO PAIR UP TWO BLUETOOTH DEVICES -
  • FIRST OF ALL GO TO SETTING>CONNECTION>BLUETOOTH>VISIBILITY
CHANGE SETTING FROM HIDE TO SHOW TO ALL OR DISCOVERABLE (IN BOTH DEVICES).
  • TURN ON BLUETOOTH OF BOTH DEVICES.
  • CLICK ON SEARCH FOR NEW DEVICES.
  • IT WILL SHOW ALL BLUETOOTH ACTIVE DEVICES
  • SELECT THE ONE WITH WHOM YOU WANTS TO PAIR UP.
  • IN OTHER DEVICE A MENU WILL POP UP ASKING FOR KEY ENTER ANY NO LIKE 1,2 AND PRESS OK.
  • NOW IN YOUR DEVICE MENU WILL POP UP ASKING FOR KEY ENTER THE SAME KEY.NOW YOUR PAIRING IS DONE,ENJOY SENDING DATA.
THANKS FOR USING FIXYA
Mar 04, 2011 | Nokia 6790 Surge Cell Phone
Samsung WEP 450 was working ok for its 1st 24 hrs paired with Samsung B2100, however will not connect now. I've gone through the pairing up process again and the device cannot be found. The only other...
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following.
1. check that BT is off on both devices
2. turn BT on on your mobile phone
3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect.
Dont try to power on the headset before turning BT on on your mobile phone.
If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again.
Don forget, that the headsets also have to be charged..
Jan 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
I need pass code to activate my wep450 ear piece
The passcode for this and it never changes is 0000 you would input this into your handset for pairing, let me know if you still have trouble, Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 03, 2010 | Samsung WEP450 Bluetooth Headset - Retail...
How to connect SAMSUNG bluetooth headset SBH 650 to my Nokia e71
When the pairing process between the E71 and SBH650 starts, try immediately to hold down, or press every half a second, the central 'call' button on the SBH650 - to force the SBH650 to think it is pairing with a new device. It took me 5-10 min of playing about in a similar situation, but eventually the SBH650 cleared it's 'memory' and the '0000' pairing code worked with another telephone...
however, I have never managed to pair the SBH650 with OS 3.0 upgraded ipod touch 2nd gen.
May 13, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
Samsung WEP450 Bluetooth Headset - Retail Packaging Logo
Top Samsung Radio Communications Experts
Jean Thiebaux
Lawrence Oravetz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
