It could have some garbage, in the processor do to a small power surge, and if you leave it unplug for 40Min., from the wall, it should reset back to normal.
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
try to restore windows to the point when it was working fine with the audio. check if this fix the problem if not then do a clean install of your windows. make sure to back up files first.
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
You should not reformat the player unless you want to clear the mp3 player completely - erasing all music, recording, and other files completely.
Once you are done recording, the Sansa takes time trying to save the recorded files - it appears that it is freezing, but give it some time - it is just "thinking."
If the recorded files suddenly disappear, it is because the Sansa player has two modes - MSC mode and MTP mode. Files that appear in MTP mode will not appear in MSC mode and vice versa. If the recordings do not show up, go into your settings menu and switch the USB Mode.
Your Camera records sound but does not play it back on the device. Go to www.vivitar.com and download the driver for your camera. Install it on your pc and you should have sound when playing video in windows media.
