You need to know if there is a delay in the water inlet valve that slows the program and finally result in the poor completion.
So while the program is initiated, observe the program to move along, check the inlet valve voltage, check the flow, once the water level is up , the motor must activate and turn. After the set time the wash stops and the water drains, check the drain valve/pump- if not clean and reset.
If there is a shut down during these times then the program controller unit is also a suspect.
