O2 Samsung SGH-E250 Cellular Phone Logo
Posted on Feb 10, 2011
Sgh-e250i function keys dead All functional keys, except the power on/off key, not responding. Number keys are working.
Suresh Suresh
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 31, 2013
Suresh Suresh
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2978
Points
5
Samsung e 250i dead solution
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Jun 12, 2009
SOURCE: I HAVE SAMSUNG SGH-E250 ONLY WHITE SCREEN - REMEDY PL.
flex problem
RECEIVER PIONNER IS DEAD , no power on
You failed to mention the model number, however, if the unit is truly dead, with slight exceptions, a factory reset will do nothing for you. If you need more assistance, or would like to inquire about repairing your Pioneer, please visit my website at audioserviceclinic.com, and contact me there. Thank you.
Why are all functions totally unresponsive.
bad/dead battery? corroded terminals? id start there
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Keyboard works except the upper symbols when I am typing in Outlook. How can I resolve this?
The upper symbols on the keyboard are called function keys usually not expected to respond when pressed. functions keysy are ysed to control the computers settings either when malfcuntions occur or computer requires alternations to another feature possibility. Every available keys are displayeable besides fucntions keys on user productivity programs.
2helpful
How do you put exponents in the calculator
For integral powers of ten, use the EE key, just above the 7 key. For example, to enter 1.3 time ten to the fourth, press 1 . 3 EE 4
To raise e to a power, use the e^x function (the shifted function of the LN key on the top row). For example, to calculate e raised to the 1.2 power, press 1 . 2 2nd [e^x] =
To raise any number to any power, use the y^x key, just above the divide key. For example, to calculate 3 to the 5th power, press 3 y^x 5 =
Hope this helps. If you still have questions, please feel free to respond to this post.
Other keys are functioning except for key number 9 and key for option
Hi, What controls the keys on phones are little IC chips inside the phone on the phone board. When it gets damaged it affects the number keys. Replace the IC chips are the number key will function.
Take care.
Oct 05, 2010 • Cell Phones
1helpful
The touchscreen on my Samsung Impression SGH-A877 does not work at all. Started about a week ago when I noticed that it was not selecting the things I touched on the screen, but selecting the entry above...
Hi,you will have to replace the flex of the phone.
The flex make the touch pad to function,also the functioning of the number keys.
When you replace the flex the touch pad and the key will function again.
Thanks for using fixya.
2answers
My laptop computer is okey except that the touch command for the cursor is not responding, if i use a mouse thru the usb port then its alright..why does the touch command for the cursor not responding?
Touch pads are not very reliable. I have seen a lot fail.
A computer repair person will need to replace it for you.
My advice is to stick with a USB mouse. Or if it is under warranty, take advantage of that warranty.
Best of luck.
14helpful
4answers
Keypad Locked on Samsung SGH-E250
my upper key pad not functioning except call and power keys what should i do? and some times hanging on white screen. pls tel me the solution
Top O2 Cell Phones Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Muhammad Irshad...
Muhammad Irshad...
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
