SOURCE: SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
SOURCE: Sony SLV-775HF issue (power off, freeze, digital cable related?)
These guys have the owners manual and the service manual for your exact model; http://www.user-manuals.com/advanced_search_result.php?keywords=sony+SLV-775HF+manual&forward=plist&osCsid=a4cf756dbc2b6f254269ca22308687e5 Sorry I haven't been able to locate these for free anywhere, Sony do not have them available online. Here is the link to the Wow cable instructions - i couldn't find much in there but you may see something that helps out, check pages 65-67 to be sure you have everything hooked up right; http://www1.wowway.com/cable/pdf/WOWGuide.pdf Here is the link to the user manual for the explorer 3200; http://www.scientificatlanta.com/products/consumers/new_explorer2200.htm and here for the FAQs; http://www.scientificatlanta.com/products/consumers/FAQs.htm Hope this helps, if you get some more ideas but still no solution, please post back and i can try again :)"
Hi, Sounds like a mechanical problem in the tape path which can be anything from the pinch roller, take up spool, foreign object (such as splicing tape lodged somewhere), brake or others. An indicator would be stretch tape. One way to check if the tape is being stretch is to rewind partially one of the tapes you have tried, eject it and open the flap/cover of the cartridge. There is a stub on one of the side of the tape that you have to push to open it and see the actual tape. Stretching if any would be clearly visible. Am afraid that you would need the services of a qualified technician for the actual repair not unless you are familiar with video tape mechanism. On the video head, offhand, I doubt if it needs replacement.Of course an on site technician would be in a far better position to diagnose it for you. Hope this be of some help and pls post again how things turn up. Good luck and kind regards.
SOURCE: Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
SOURCE: Hi! SONY DVD/VCR SLV-D271P player.
Please get the code here :
www.dvdoverseas.com/dvd.htm
www.regionfreedvd.net/
Regards, Jay__Ujh67g
