Sony SLV-D360P I was recording a program from the TV when all of sudden the VCR turned off and the...
(More)
Sony SLV-D360P I was recording a program from the TV when all of sudden the VCR turned off and the cassette got stuck inside the VCR and it won't come out and the VCR won't turn ON or start now, but the TV work. How can I fix it?
Worked fine until a power outage in the house. Now can't get it to turn back on. It was connected...
(More)
Worked fine until a power outage in the house. Now can't get it to turn back on. It was connected to a surge suppressor so not sure if this is the problem.
When I try to program something to record the dvd light turns on and will not allow me to change to...
(More)
When I try to program something to record the dvd light turns on and will not allow me to change to the channel I want to record in the programming mode. Is there a solution for this.
I am trying to connect a PS2 through my Sony SLV-D360P DVD/VHS player. Which set of inputs should i...
(More)
I am trying to connect a PS2 through my Sony SLV-D360P DVD/VHS player. Which set of inputs should i plug the red/white/yellow plugs into and what do I set the player to? DVD, video, etc
My unit is dead except for the orange progressive light that is flashing. I checked the only fuse I...
(More)
My unit is dead except for the orange progressive light that is flashing. I checked the only fuse I could find on the circuit board and it's fine. Any suggestions would be appreciated. Thanks.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
