Bad grounds are common and need to be resoldered. Next you may already have a few bad capacitors that will need replaced. If you can locate the audio output IC, you should check in this area for bad capacitors and bad grounds. 99% of the time a bad ground and bad capacitors will offer you goofy problems in a TV. So take heed and inspect, resolder and replace those capacitors. Thanks for asking and show a few hands of support!
