If the mechanic did not replace the exhaust pipe gaskets in the head or on any connections between the head pipes and the mufflers , the air leaks could be igniting unburned fuel in the exhaust , causing the popping and back firing. Try replacing any gaskets in the exhaust system.
If you have a flat spot or hesitation when accelerating than you probably also need to rejet the carburetors. Bigger main jets should fix that condition. A jet kit may also contain differently tapered needles for the slides to help compensate for the change in the acceleration curve.
SOURCE: hi i have purchased a yamaha xvs 650 vstar classic
popping on decel is from a lean condition. More likely from a lean, or too small pilot jet.
