When the dryer stops can you advance the timer a little to turn off buzzer? Or when you open the door does the buzzer stop? I was trying to find a schematic for that model but I have had no luck. Power should come from the timer to the buzzer. If you know how to read a schematic. Unplug the unit and remove the back to the control panel. Check to make sure that all the wires to the timer are on the right connections. You may need an appliance repair service from your area to come out and diagnose it for you.
SOMETIMES THE DOOR MIGHT SEEM PROPERLY CLOSED BUT ITS NOT TRY RE ADJUSTING THEM AND SEE IF THAT WORKS ALSO THE DOOR CLOSED CONTACT CAN CAUSE THE BUZZER TO GO OFF FOR NO REASON.
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
