When on wireless connection..it will disconnect and reconnect with limited connectivity...when on LAN it is fine....i have uninstalled wireless from device manager..even removed drivers and got new ones from support.acer.com ...i have done Norton Removal Tool also ...
What wireless client are you using? The windows wireless client? Example Netgear or Linksys will have their own clients that you can use to connect to your router with.
What kind of wireless card is it?What wireless client are you using? The windows wireless client? Example Netgear or Linksys will have their own clients that you can use to connect to your router with.
You can't post conmments that contain an email address.
Connect your computer to an Ethernet connection to go on the Internet. Go to the Emachine customer support website and select drivers download section.
Open Device Manager. In the Device Manager window, click the plus (+ ) sign next to Network adapters to expand the selection. Under Network adapters , click to select the appropriate wireless LAN adapter. On the menu bar, click Action and then click Properties . In the Properties window, click the Power Management tab. On the Power Management tab, click to uncheck the box next to Allow the computer to turn off this device to save power . Some WLAN adapters have another power saving setting in addition to the one on the Power Management tab. Click the Advanced tab and try to locate a power saving setting. If it exists, disabled it. Click the OK button.
Your Intel wireless-G 2.4Ghz is defective, all you have to do is test another wireless LAN to make it sure that is working via USB panel. I encounter this kind of problem and wish it would be the same like me. Usually this kind of problem cannot see itself that is defective but it is working good to your PC. Just try a new wireless LAN if might work. Good luck!
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
First check your wi fi switch is on in laptop. Second also check that your wi fi network padapter found your router netwrok in my netrwork places. Then when u cliko n connect what happen let me know please.
You should be able to reset the router.look on the back and see if there is a small, paper clip size, hole. Reset it back to default and try to reconnect.
