Please mention the make of the phone so that we are able to help.
For Nokia the code is 12345
Hello
There are two type of resets.
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard Reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
on/off + * + 3
Before making a Hard reset better backup all your important information: contacts , memo...etc
Hope this helps, if so do rate the solution
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Settings
RESTORING
FACTORY SETTINGS
initialization
