SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
SOURCE: Schwinn S40 DSX part name
I think you will find they are called Jockey Wheels ,
All the best smirf 617
SOURCE: Adjusting seat on a Women's Schwinn Jet Star 26" bike
It sounds like the bike you bought was too big for you. Your only option here is to replace the seatpost with one that does not have this feature. You can pick up a seatpost at a bicycle shop and they should install it for you, too, if they are a good shop.
Hope this helps a little,
matt
SOURCE: Frontier GSX Women's Mountain Bike: what is proper way to remove and re-install the qu...
Unhook the front brake, loose the quick release level and push the tire off the fork. reverse procedure to install.
