Hi Hibbs8829
Generally fuses are located on the PCB attached to the power transformer terminations. In some instances the only primary fuse may be a thermal fuse located inside the power transformer that may have failed. This one you cannot see from the outside. They are replaceable, but you will need to get into the transformer somewhat to sort it out. Other than that, there are often fusible resistors and circuit protector devices on the PCB. These can be a little difficult to find if you don't know what you are looking for. Good luck
regards
robotek
