Rosetta Stone Japanese Level 1 & 2  for PC, Mac  Logo
A
Anonymous Posted on Jan 15, 2011
When I try to open the program, the window pops open for a split second then seems to jolt to the left, off of the screen. It says it's running but I can't do anything with it. It is the Rosetta stone version 3 for the Mac.
cole man
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Jan 15, 2011
cole man
Expert
Level 2:
New Friend:
Answers
118
Questions
0
Helped
17574
Points
335
Check expose/spaces to see if you have minimize change windows or something hot keyed to the corner of your mac that would make it go off every time your pointer is in that corner
I have a iPad Pro and my screen has changed from a full screen to one that us 1/2 full what is my problem
How to Turn Off Split Screen on iPad Split View is enabled by default on the iPad. To utilize the feature, you can drag an app from your dock to the right or left edge of your screen to open the app on a portion of the screen. If you have multiple apps open and want to close one without turning off the Split Screen or Multitasking functions in settings, you can return to a full-screen view of a single app by dragging the edge of the app you want to remove to the edge of the screen.
If, however, by "getting rid of split screen on iPad" you mean turning the feature off completely, that's something you can do in Settings. To turn off split screen on the iPad:
  • Open the Settings app on your iPad.
  • Tap General.
  • Select Multitasking & Dock.
  • Toggle off Allow Multiple Apps.
How to Get Rid of Split Screen in Safari on iPad Using split screen in Safari on iPad was a new multitasking feature for iOS 10 that continues in iOS 12. This allows you to open two separate Safari web pages simultaneously on your iPad. To start, open Safari on the iPad. You can then open a second Safari tab in split screen in one of four ways:
  • Tap and hold a link; select Open in Split View.
  • Tap Command+N on an external hardware keyboard to invoke Split View.
  • Drag a tab from its space to either the left or right side of the screen to open it in split screen.
  • Tap and hold the icon that opens your tabs view in Safari. It looks like two overlapping squares. When you tap and hold, options will pop-up. Select Open Split View.
But what if you want to get rid of split screen in Safari? What if you're done using the two tabs-how do you turn split screen on the iPad off? To close split screen in Safari on your iPad, you can do one of the following things:
  • Drag the tab(s) from one of the screens to the other. Once the last tab has been dragged to the opposite side, Safari will return to full screen, which will turn off split screen.
  • Or, you can tap and hold the tabs icon, which looks like two overlapping squares. Then select Merge All Tabs. This will merge all your Safari tabs back into a single window, which gets rid of split screen.
2helpful
2answers
How do i stop my windows intaller trying to install symantec antivirus msi file
Step 1:
Stop Windows Installer From Popping Up b> The older a computer gets, the more junk it accumulates. A great number of computers out there don't start up without a thousand things popping up demanding your attention. Windows Installer is one of the more notorious pop-up offenders for Microsoft users. Stopping these pop-ups can prove challenging, however, there is a way.
On your computer's desktop, click on the "Start" tab, typically located on the bottom left of the screen (in Vista it may be the Windows symbol rather than the word "Start"). Now locate and click the program titled "Run." Vista users can locate this program by typing "run" in the search box at the bottom of the "Start" menu. Once "Run" is open, type "MSCONFIG" into the empty box and click "OK." This will open the System Configuration Utility. With the System Configuration Utility open, select the tab labeled "Services." Scroll down the list of services (it may be beneficial to click the "service" column to sort the services alphabetically) until you find the "Windows Installer" program. Now click the check box beside the Windows Installer name and click the "Disable" button at the bottom of the System Configuration. Congratulations, you have stopped "Windows Installer" from popping up!
Screen is split improperly
It sounds like the the split screen mode in windows 7 has accidently been activated. you can set the task bar at any location, (top, bottom or side) by right clicking a blank area of the taskbar and then left click on properties. Try that and if things still arent correct, try grabbing the sides (or top or bottom) and dragging them to their correct location. (To drag....place mouse curser on edge, hold left button and move mouse to place)
Yes why isnt my crystal cam working it will pop up but the window is a black screen?
mate try to download split camera here...www.splitcamera.com install then choose your cam in the source of split cam..always open splitcam when your trying to open cam..it will surely work
Search window opens when not doing a search
That is a sure sign of an infection.
First of all perform all the Windows updates.
Second, run your AV program, an antispyware, and hijacker programs.
Its going to be lenghty and tedious job, but necessary if you want to keep your information.
Another solution could be make a backup of all your data, and format and reinstall your OS.
Don't forget to rate this answer if it helps.
Ford escort 1.6i 1995
replace the stearing rack you have a hydrolic leak or ware in the rack.
2answers
Claris Draw v1.0v3 will not start with XP
I found that Draw runs on XP but I have to tell it each time it opens where to find the CLARIS folder, and when it does run it won't respond to the OPEN menu item. I can still open files though by clicking on the file to open, but it's pretty inconvenient. Looks like I'm going to have to run the program on my old pre-XP windows machine.
Top Rosetta Stone Computers & Internet Experts
vince
k24674
Vinho Xie
Vinho Xie
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
