SOURCE: I have a new Sony
Hello sorry the M-2000 don't have the ERASE feature but your only option is to get a tape eraser you can get one at http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx just think positive your unit will last longer the eraser prolong the life of units just pass the microcassete once on the eraser and is done full erase :)
SOURCE: how do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
SOURCE: We have a Sony BM-575
Hi,most times,when a Sony BM-575 recorder/dictator malfunctions,what i will advice you to do,is if the Sony BM-575 recorder/dictator is still under warranty,you could simply take it back tothe store for replacement..They are very delicate to handle by any other person.
Or you could simply contact sony tech support..
Also if you can get an expert that can fix it properly ok with that.....
You can check the manual and see if it has a reset button to reset...
That will do...
SOURCE: I have a M-2000 Microcassette
This unit does not have erase. You can use a microcassette tape eraser which you slide the tape thru.
Hello unfortunately this unit don't have a erase function the only thing you can get a Microcassette eraser this eraser will help even if you decide to buy any micro or mini cassette transcriber when you used the erase function on the unit the life on the head, rewind, gears and motors get reduced by using this method if you used and eraser it erase the tape Magnets are on top and bottom eliminating the need to flip the tape allowing complete erasure on one second heare is a eraser you can buy and it is cheaper than buying other unit. http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx
