Question about Sony M-2000 MicroCassette Transcriber Refurbished
How do i get a sony microcassette transcriber m-2000 to play/rewind/fast forward continuously?
Sony microcassette transcriber m-2000 will play/rewind/fast forward for only a few seconds before it alarms and stops. how do i get it to play continuously?
mark liikala
    Problem Solver:
  • 18 Answers
Probably has a bad sensor belt (small belt attached to silver and black reflective wheel).
Posted on Dec 29, 2014
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
WON'T PLAY BUT WILL REWIND AND FAST FORWARD
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and it will be difficult to remove.
Hope this helps.
Sony m-2020 tape will not move in record or play mode
here's the manual of this recorder. You can take a look at it to see if there are any explanations regarding the error:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000033419.pdf
Oct 04, 2012 | Sony M2020 / M-2020 Microcassette Dictator...
New problem
take it back for a warranty refund and get a different machine
Oct 31, 2017 | Sony BM-890 Microcassette Transcription...
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
How do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
Jun 07, 2010 | Sony BM-850T Desktop Cassette Transcriber...
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
Does not play. will rewind & fast forward
Its most likely the cam gear. Any sony dealer can replace the gear.
Jan 07, 2009 | Sony BM-87DST Desktop Cassette Transcriber...
Sony M-2000 MicroCassette Transcriber Refurbished Logo
651 people viewed this question
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
