I have a VGN-AR320E PC Laptop. When I power it up I see the VAIO logo, then the error message: OPERATION SYSTEM NOT FOUND. What can I do to remedy this problem?
I did!, go to hp drivers and look for zv6000t all the drivers working for the vaio, only you have to install manually and look for each file and install for sure work...
For a factory reset there are two installation options: C:\ drive recovery System recovery
System
recovery will rebuild the partition. C drive recovery will simply re
install the C drive on the active partition. When you do full system
recovery we create a hidden partition that is read only. this gives you
the F10 boot-able recovery partition tools.hit f-10 on boot up
if your are talking about your internal web cam, then it seems some problum with your O.S, reinstall your windows (like Xp Professional Edition) this will solve your prob...
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
