SOURCE: dvd remote
remote controls made by One-for-All that can
be computer programmed to extend their capabilities.
that's all for now
See http://www.hifi-remote.com/
SOURCE: dvd player will not open
the problem is internal and the only way is to bring it back to the store you just bought it. because it is still under warranty, since it is just newly bought.
Good luck
do this with the unit off:1Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
Step2Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
Step3Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Step4Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
Step5Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
Step6Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
if this helps dont forget to leave a fixya rating as thats how we get paid
SOURCE: My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
SOURCE: My dvd player won't read disc, the door keeps
change the motor belt charge it´s located downside the disc tray
