disc won't play. message on screen: "this disc cannot be played, please check disc", same...
(More)
disc won't play. message on screen: "this disc cannot be played, please check disc", same with other discs
Hi! Does anyone know how to unlock a Samsung p241 from it regional code? I need it to be in Region 4...
(More)
Hi! Does anyone know how to unlock a Samsung p241 from it regional code? I need it to be in Region 4 but making it multiregional would be even better. I have tried the code 23394 but the code does not register. I would love if someone could help me out on this :) -Juju
My cable went off all of a sudden which shut off the dvd player. now it won't turn on and it has a...
(More)
My cable went off all of a sudden which shut off the dvd player. now it won't turn on and it has a dvd in it that i need to return to the store tonight...of course. lol I'm not sure if it's dead now or what. I think this happened once before but then I tried to turn it on again and it worked but it seems not to be working this time. Pls help Thanks
last week dvd player worked, today when i put a dvd in, it acts like it is loading, then message on...
(More)
last week dvd player worked, today when i put a dvd in, it acts like it is loading, then message on tv screen saying to check disk, this disk can't be played....... gee it played in the same dvd player last week. whats up with this? please help with this problem, thankyou
My Samsung HT Z3-10 dvd player when plugged into any T.V via scart lead displays all the picture in...
(More)
My Samsung HT Z3-10 dvd player when plugged into any T.V via scart lead displays all the picture in a shade of green. Any ideas? Kind regards Edd.
I have a Samsung P241 that when a DVD is loaded, the loading light begins to flash, the DVD starts...
(More)
I have a Samsung P241 that when a DVD is loaded, the loading light begins to flash, the DVD starts to spin and then the unit shuts down. Then the start button, the play light, and the loading light all start flashing at the same time. Any ideas?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
