If this is the Ce Net Book, then perhaps the suggestion I made for the Sylvania SYNET07526 CE note book will do the trick for you as they both use the same WiFi application. see below It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver. sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing Additional Information When I try to sign on with the red X showing, I get "The page cannot be displayed If I then double click on the icon down in the right corner I elucidated above, RT28701 opens up to "Internet Protocol (TCP/IP) with all zeros in the IP address field, and Subnet Mask, with no entries in the default gateway. That is a clue to me that the auto sign on has not found a viable network or needs something else. If I then click on Wireless Information tab, The list of available networks appear in the box. The machine keeps trying to associate my previous entered name site with my prefered site and tells me the signal is good, but it cannot link up. This is a signal to me that it has lost my Network Key or that the software has failed or both. I then click on advance and delete my prefered network and hit OK, this will force the software to ask me for my network again, and notice that the prefered is missing. I click on the name of my network again and then hit connect., then the Wireless Network properties window opens up and I can insert my Network Key again after I uncheck the "The key is provided automatically" box. I enter the key and hit the OK button. I still do not get a connection, so I reboot the machine, and wait for about 30 seconds and the machine synchs up because the little RED X under the icon has disappeared. Now the machine will hook to the internet as long as I want to, but sometimes when I turn the machine on it will not synch, so I go through the above sequence again. The secret is once you have entered your key and ask for the machine to synch up you have to reboot. Why? I do not exactly know, but I suspect that the WiFi driver looses it
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
