20 Most Recent
Coby MID TABLET PAD WITH TOUCHSCREEN Questions & Answers
How to install flash player
http://www.multiupload.com/UP_SZP9GGNBDV
1. Download file above to your tablet (flash.apk)
2. Mount the tablet to your computer
3. Drag the flash.apk file to your tablet/sd card
4. On your tablet - AppsLib - download a file explorer (Linda File Manager)
5. Locate the APK file you downloaded, tap to install.
Enjoy the flash.
Forgot pattern on coby android
This procedure will delete all items (files) and entries on the MID7015-please back up files on your computer if possible first. This is a Master Reset Procedure.- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
- Click "Power Off" and select "OK"
- Once the unit has been turned off. Press and hold the "back" button(silver tone button) and "power" button simultaneously for eight seconds.
- When the Android Icon and warning triangle appear , press the "back" button )silver tone button) once.
- The Android recovery screen will appear. The "Home/Menu" button will allow you to scroll up and down.
- Press the Home/Menu button to scroll to "Wipe Data/Factory Reset" Then press the "back" button
- On the next screen Scroll to "yes-delete all user data" Press the "back" button.
- On the next screen Choose "reboot system now" and Press the "back" button.
- You will now be able to access the tablet.
Touchscreen is not working properly,
This is a common problem with most of the touch screendevices. This problem will occur when touch screen connection mal-function andhave power problem.
The solutionfor this problem is:
First let the battery totally drain until it was dead and donot turn the device on. After completing this process, plug it back and it willstart working again.
Hope this will help you. Good Luck.
My yoshima smart pad is
To Whom It May Concern,
I am very sorry to hear that. I would be more than happy to help. Please try restarting it and if it doesnt turn off then wait for the battery to die. If restarting it doesnt help then there is a problem with the Tablet. If it is the Tablet then you should see if you have warranty or if you can get an exchange.
Thanks,
FixYa Expert
****Please Rate Thumbs Up if you like my Solution****
