Symphonic SL2860 VHS VCR Logo
Posted on Jan 03, 2011
Stop recording a programmed recording in progress
tip
How to computer capture a sound card
<p>Record and recording the sounds through the computer sound is a relatively simple procedure that only a free space on the hard disk, suitable software and a short profile of TRS cable is required. Windows computers usually come with an audio recording program, from the entertainment equipment a program is found in the Start menu. <br /> <p><br /> <p>1. Turning off the computer speaker's audio jack of your computer's sound card. <br /> <p><br /> <p>2. Attach the small RCA cable into the sound card speaker output. <br /> <p><br /> <p>3. Connect the other end of the RCA small correction to the microphone port on your sound card. <br /> <p><br /> <p>4. Start the Sound Recorder program from the Start menu. Click the Record button. Tell your computer to the sound you want music or video progress bar to take to indicate when the movie is ready to play. Click the Record button, which will continue to record. <br /> <p><br /> <p>5. Click the File menu in the Sound Recorder program and select "Save As". Enter a filename and click Save. <br />
on Jun 22, 2011 • Computers & Internet
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
I want to stop the recording i have programmed whle it is running. toshiba D-R7
To stop a timer recording in progress:
On the front panel of the recorder itself:
Press [STOP].
For later models of Toshiba DVD recorders, also add to the above step:
On the remote control:
1 Press [STOP].
2 Select "Yes" using [up/down arrows], then press
[ENTER\OK].
1helpful
How can I stop a vcr recording program once it has started?
For your VCR try this procedure:
While the recording is in progress, press the power button and then press the stop button. The TIMER indicator should go out.
3helpful
I have a sanyo cinema progressive dvd player....lost the remote and am trying to program universal...what remote code should I use?
what kind of universal remote do you have???? it can vary sometimes from remote to remote
also, do you have the model of the sanyo system??? some models they make are made by other companies so you would have to use their code.
LG 42 LCD TV HDD initialization in progress message
Change the hdd or remove it then connect it to PC and do for it format , it will work .
6helpful
I put my dvdr phillips recorder on progresive scan no picture
You will have to reset the DVD player in order to undo the progressive scan option. Since you cannot see a menu to do so...
1. Unplug the dvd player from the outlet
2. Press and hold down the STANDBY-ON m button on the front of the Recorder while reconnecting to the power outlet.
3.Release STANDBY-ON m when '  ' appears in the display. All the information stored in the memory (programs, time, TIMER) will be reset (cleared).
Hope this helps with your problem, thank you for stopping by Fixya! Please leave a positive rating if this solution works for you.
Progressive scan button is stuck
What progressive scan "button?" On the unit? Remote? In the LCD display? I don't see one....
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
