After having my passat towed and replacing the head and cams the trans quit working. Motor runs fine but will not move in gear, forward or reverse. I have found a used trans from a 2000 VW passat with same engine but the three letter code on the ID plate is different.Will this trans work in my 2001 passat?
The
engine and the automatic transmission (transmission control is only
for automatics, engine is still computer controlled no matter the
transmission type) in this vehicle are computer controlled and in
most cases when a fault occurs a fault code is stored in the memory
of the computer control module. There are exception to this, such as
the Mass Airflow Meter and fuel pressure problems. What must be done
is to have all the basic testing done such as a scan of the system
for fault codes as well as a check with a live data scanner tool for
engine functions that are not within range of normal, a trained
technician is required to know what is correct and what isn't, then
based on careful diagnostics done from a factory repair manual the
correct part is replaced or the wiring repaired or the computer
replaced (known as the PCM), which is very rarely the problem. Other
basic checks must be done as well such as mechanical problems with
the engine as well as engine state of tune and mileage on the engine.
The transmission can have mechanical issues as well such as no gear
engagement at all or a failed pump or other pressure related
problems.
In winter months the car will start in limp mode in the morning. The lights cluster on the gears all light up together. I then put car in reverse and the whole car jumps as if the transmission is 'coming unstuck'. Then I turn engine off and back on and everything fine. Smooth trans' otherwise. This problem dissapears over summer and returns every winter's morning.
